M
MohEllayali
Hello,
I started to work with signal storm for library chracterization ...
my question is about db_gsim, when I run it signal storm , generates a new netlist and it includes internal nodes ... can I force signal storm to pick a specified internal node instead of that it chooses ???
I tried to modify the spec file before running db_spice and replace the internal nodes by other ones ... the simulation passes ... and the delay and power consumption don't change . is it normal ?? how signal storm uses the internal nodes .... ???
even if I change only the spec file and so, subckt and spec don't match ... the simulation still passes ...
I can't see what ss do with internal nodes and how it do it
Many thanks in advance
