Hi, usually we would like to know what is the output power(Pout1dB) at input 1 dB compression point (Pin1dB). Does this mean first I find Pin1dB and then do the loadpull at this input power? Basically how do I choose how much input power I should provide? Thanks
Yes, you should apply P1dB(in) to do load-pull..Because this point where the nonlinearity starts to become dominant on the amplifier's performance so it's a kind of threshold..
Yes, you should apply P1dB(in) to do load-pull. Because this point where the nonlinearity starts to become dominant on the amplifier's performance so it's a kind of threshold..
Yes I was doing that, I could get all the Pin1dB points. But now I need to figure out how to run another simulation for loadpull at different frequencies using their respective pin1dB points.
analysis('hb parameter Pin )
paramAnalysis("frequency")
paramRun()
[I]save Pin1dB points ..I don't know what to do here[/I]
analysis('hb Parameter mag and theta )
[I]Use the saved Pin1dB points[/I]
paramRun()
Although most RF systems are designed for nominal 50-ohm input and output ... Further, the power levels in 4G wireless systems and upcoming 5G ... Q: What's the general procedure for making load pull tests and using the results? ... a dozen among which to choose) with suitable application support in ...
After reading this post https://www.edaboard.com/showthread.php?386008-Power-Amplifier-Design, it makes me think.
What is the pout that is shown at optimum load , Is it p1dB(out) or maximum power (Psat). As Vivekroy mentioned in that post loadpull gives maximum power for that particular optimum load. Then what is the point in giving P1dB(in) to do loadpull?
The pout for optimum load is the pout you would get if you connected the optimum load (from loadpull simulation) and put in the input power at which you did the loadpull.
It is not necessary to give P1dB for loadpull. For example, for constant envelope waveforms (eg. FM), you give input power corresponding to the point where you get maximum efficiency which can be far from P1dB.
