rey843
modelize ground hfss
Hi friends,
I am trying a simple simulation, such as a monopole on a finite size PEC ground plane. How do I model it in HFSS? What I did is that I assigned the plate as PEC, but not infinite ground plane. Then I used either a wave port or lump port for excitation. I had air box all around the monopole and the plate. I mean the ground plane plate is somewhere in the middle of the air box. I got some result, but I do not if I should trust my results.
So, anyone here has done a similar problem? Can you share what you did? Thanks. -- Rey
Hi friends,
