Plecto
Full Member level 5
Hi. I just scavanged a transformer from an old Panasonic stereo system, but there are no markings on the transformer. It is about 8x8x8cm, weighs about 1kg, has a 1.25A fuse on the primary side and a wattage rating of 156W on the back (back of the stereo system). I'm not sure what these 156W means. The amp is supposed to be 2x50W so I guess 156W power supply would make sence, but those 150VA transformers I've been looking at are usually bigger and heavier than this. I am also curious about the inputs and outputs. It has four inputs on the primary side and 9 outputs on the secondary. Why have they littered the thing with so many outputs and inputs? Surely there's only need for two input pins and three output pins?
