How can you make a shared folder in Linux?
Batje
Newbie level 3
Linux Problems
Is that difference between, as example, Windows XP?
Linux Problems
tried using SAMBA?
or NFS?
powerful tools for these tasks.
Re: Linux Problems
No, I use SUSE 9.2
Linux Problems
You can use samba.
SUSE is the Linux distribution.
Samba is a set of software which can run in SUSE.
Re: Linux Problems
navigate to sytem tools,server configurations,then samba & nfs server settings.
Re: Linux Problems
If you are going to sharing a folder with a computer runing linux ,then you can use nfs.If windows,then use samba
Linux Problems
After you setup Samba or NFS...
select folder, go to properties and select share...
remember to add "fileshare" in the usergroups.
