below is the code for frequency counter...make necessary ammendment according to your requirment
;this is for memory Placement
Prog equ 0000h ;Starting address for the program
BitVar equ 0 ;where the Bitsegment starts
DataVar equ 024h ;were the Data Segment starts
;some Constants
T0_MASK equ 0F0h
T1_MASK equ 00Fh
;Symbol definitions used in "main" to control the LCD display.
;not used at all
LCD_CLR equ 01AH ;clear LCD command
LCD_LF equ 0AH ;LCD line feed (next line)
LCD_CR equ 0DH ;LCD carriage return
;some port definitions to make the code more readable
RAM_A16 Bit P5.0
EEP_ENA Bit P5.2
bMode Bit P5.3 ;Check this PortPin to read Mode of op
;Place for data vars
DSEG at DataVar ;start at DataSeg
GateTime: DS 1 ;the GateOVCounter
OverFlow: DS 1 ;
frequency: DS 4 ;actually a UINT32 Value
bufindex: DS 1 ;
outbuffer: DS 16
T0Vect: DS 2 ;for saving the actual Irq Vect
T2Vect: DS 2 ;
STACK: DS 1 ;stack starts here
BSEG at BitVar ;place first bit here
bReady: dBit 1 ;1: ready for output
;Code starts here
CSEG at Prog ;opens the code segment
ORG Prog + 0
LJMP Init ;should be placed here
CSEG at PROG +0Bh ;Timer 0 overflow interrupt
PUSH T0Vect ;Attention this is very tricky
PUSH T0Vect+1
RET ;ret starts the IRQ
CSEG at PROG+02Bh ;Timer 2 overflow interrupt
PUSH T2Vect ;both Functions need 6 clocks
PUSH T2Vect+1 ;to start the IRQ
RET
CSEG at PROG +100h
Init:
CLR EAL
; SETB RAM_A16 ;Make bit A16 of 128K Ram "high".
; CLR EEP_ENA ;Disable EEPROM.
; CLR P5.1
MOV SP,#STACK-1 ;init the stack V0.1 STACK-1
;since we have a stack now Rest should be placed in Sub routines
Main:
; CALL INIT_LCD ;make all neccesarry LCD Inits
; JB bMode,Main1 ;0 Frequ Mode 1 Period Mode
SETB TR0 ;both Timers are runing
SETB T2I0
SETB EAL
MainLoop:
JNB bReady,$ ;wait for Result
CALL HandleFreqOutput
JMP MainLoop
;DispalyHandler when executing Frequency
HandleFreqOutput:
CLR A
MOV TL0,A
MOV TH0,A ;clear the counter
MOV Overflow,A
MOV GateTime,#20
MOV TL2, # Low (-49999) ;V0.2 new ReloadValue -49999
MOV TH2, # High(-49999)
SETB T2I0
SETB TR0 ;restart both Timers
CLR bReady
;now you have 1 s to format the output as you want
;you will need some 32 Bit Division Functions
;here a short example for doing hex out to a buffer
MOV bufindex,#OutBuffer
CALL BufHexOut
RET
;subroutines
InitT0Freq:
MOV A, TMOD ;initialize Timer 0 to Counter mode
ANL A, # T0_MASK ;change only T0
ORL A, # 5 ;Mode 1 16 Bit Counter
MOV TMOD,A
CLR A
MOV TL0, A
MOV TH0, A ;Timer0 to zero
SETB ET0 ;allow T0 Irq
RET
