how can i make this code synthesisable?
yushionly
Junior Member level 2
hi~
when i synthesis the code below,it tells me that "!==" is not synthesisable,how can i change it?
thanks
for (n=0; n<addr_width; n=n+1)
begin
LATCHED_A[n] = (NOT_A[n]!==LAST_NOT_A[n]) ? 1'bx : LATCHED_A[n] ;
end
when i use "!=",the result is not right, this code is a part of a memory code
Do you understand the purpose of the "case inequality" operator !== in this place? It's explained this way in the Verilog standard:
a !== b a not equal to b, including x and z
Whatever it's meaning in the presented code may be, the constant 1'bx isn't synthesizable as well. Obviously, the code is only meaningful in simulation.
I noticed, that the unsupported constructs list from link #1 isn't fully correct. Initial blocks are usually supported by FPGA synthesis tools to specify the power-up condition of registers.
