how can i install windows with linux (mandrake, red hat)????
carane
Newbie level 5
Newbie level 5
i can´t install windows with linux mandrake, i need to have winlinux, but it´s get a error message when i define the resolution of the monitor or video card. Please tell me which are the principals steps to install winlinux. thanks
PD: IS COMPATIBLE THE SIS 630 VIDEO CARD WITH LINUX MANDRAKE?
NeologiK
Make a partition and install linux, don't use winlinux, it is not as updated as the regular linux distributions, go for mandrake, www.linux-mandrake.com, it's very easy ro install (if you have a partition ready!!)
tlihu
Full Member level 6
Full Member level 6
Re: how can i install windows with linux (mandrake, red hat)
Do you mean simultaneously running Windows (guest OS) on Linux (host OS) or vice versa? Then go for VMware workstation. I tried v3.0 and worked fine.
NetAnts
Newbie level 6
Newbie level 6
First install Windows, then Linux.
as title.
NeologiK
no, it seems he's using a version which installs in the FAT32 filesystem.
btw, I was never able to save my configuration when I used vmware, on the subject, when you first launch vmware from linux, and you boot windows, I can see that windows tries to detect new devices etc.., is it a normal process or is there something wrong (I mean, should I accept everything that's going on or what?) thanks in advance!!
tlihu
Full Member level 6
Full Member level 6
I guess it is normal 'cause Windows tries to detect devices for PnP. It happens when i power on the virtual machine as well.
NeologiK
okay, but does it have to go through the detection process each time you run windows as a guest host (hence saving the configuration)??
ilamseeker
Member level 1
Member level 1
yes the grub bootloader is very good for dual boot...i have installed both windows and fedora ...thanx to grub...
louisnells
Full Member level 4
Full Member level 4
winlinux is not a better idea. Because it installs on usual FAT32 filesystem.
FAT32 has got lot of limitations like it can't store anyfile greater than 2GB also there is a good chance of file corruption. Better idea is to install LINUX in a dedicated EXT3 filesystem and use GRUB or LILO for boot to either windows or LINUX.
hr_rezaee
Advanced Member level 3
Iran-Mashhad
Hi
first install windows then install linux on other partion.
regards
louisnells
Full Member level 4
Full Member level 4
Acually the order of installation is not important. You can install it any order you like.
All you need to do is that you have to write the GRUB or LILO boot loader as final step of installation. If you install Windows as second step, most of the distributions provide options to boot in to the LINUX partition in rescue mode using the installation CD. Once you gets in using the installation CD try to run the boot loader on to the boot partition or master boot record.
hr_rezaee said:
Hi
regards
fdiblen
Member level 1
Member level 1
try qemu
mmike
Banned
Full Member level 2
If you want run both at a time use VMWare
Anno
Full Member level 1
South Africa
there even exist a prog win4lin for such purposes
bangash
Member level 5
Member level 5
London
hi carane,
i have installed it last week with already installed windows xp.
first boot pc with cd-rom and insert mandraka
it will ask u few simple qs.
install it on seperate drive(not with xp) having ext3 file system.
then enjoy it
spweda
Full Member level 3
Full Member level 3
Try to use crossover tool to install WIndows Application such MS Office.
