[SOLVED] How can I create calculable Time values in simulation VHDL codes?
Port Map
Full Member level 1
I'm interested in using a calculable Time value in my simulation codes.
Like code below, I want to calculate parameter cDelay_ns from other defined values.
But this code not works, and brings the error below.
Plz tell me that how can I solve this problem?
code:
(91) constant gRs232Rate : real :=115.6;--Kbps
(92) constant iClk_period : time := 10 ns;
(93) constant cDelay_ns : integer :=integer(10.0 * 3.5 / gRs232Rate * 1.0e6 );
(94) constant cT3p5Delay : time := cDelay_ns ns;
error:
# ** Error: Test_Tb.vhd(94): near "ns": expecting ';'
constant cT3p5Delay : time := time( cDelay_ns );
Oh, That was very nice,... So thanks..
But where is the documents for learning something like this?
Oh, I tried this new code but not worked..
# ** Error: Agc_Tb.vhd(92): Illegal type conversion from std.STANDARD.INTEGER to std.STANDARD.TIME (numeric to non-numeric).
