How can I connect a PIC microcontroller to the internet?
bereton
Junior Member level 1
connect microcontroller to internet
Hi people,
Its my first time using this forum and I feel a bit dumb actually as i feel y'all are too clever.
I'm trying to connect a PIC18F452 microcontroller to the internet. Does anyone have any ideas on how I can achieve this? :oops:
olimex pic web
Hi Bereton,
You may wish to visit Microchip website to find out more. There is an app note on how to connect the PIC to the ethernet.
Regards
pic connect to internet
You can use a PPP connection. There are an implementation for PIC microcontrolers called TCP/IP Lean. I have the source code, but I can´t the book that explain the code. You can use a modem or Ethernet connection.. :D
microcontroller connected internet umts
Hi there,
The following link show how to connect a PIC microcontroller to a NIC (network interface controller) card. This link also illustrates how to build the webpic = PIC (simple) web sever.
pic internet
TCP/IP links for PIC:
h**p://w*w.edtp.com/download/iap/iapbook.zip
h**p://w*w.edtp.com/download/eth/edbbook.exe
h**p://w*w.edtp.com/download/inet/inteng.exe
h**p://w*w.edtp.com/download/ethtutorcs/tutorcs.htm
f*p://f*p.microchip.com/download/appnote/internet/00724.zip
h**p://w*w.chipcenter.com/circuitcellar/october00/c1000fe1.htm
h**p://w*w.chipcenter.com/circuitcellar/october01/c1001fe1.htm
h**p://w*w.chipcenter.com/circuitcellar/november01/c1101fe1.htm
h**p://w*w.microchip.com/1000/pline/tools/picmicro/demo/pdemnet/index.htm
h**p://w*w.microchip.com/1000/suppdoc/appnote/category/internet/926/index.htm
h**p://w*w.microchip.com/1000/suppdoc/appnote/category/pic16/962/index.htm
h**p://w*w.microchip.com/1000/suppdoc/appnote/category/pic16/963/index.htm
h**p://w*w.elektroda.pl/ftp/TCPLEAN/tcplean_cd.zip
h**p://w*w-ccs.cs.umass.edu/~shri/iPic.html
connecting microcontroller to internet
Look in this topic: **broken link removed**
how to connect microcontroller to internet
read tcp/ip lean, if u can get it. it gives the detaik explanation of this.
connect to internet by microcontroller
Or you can try PIC-WEB from hxxp://www.olimex.com
If you don't want to solder :)
connecting microcontroller with internet
u can search "i-connector" in google.com
usually this connector is attached serially to microcontroller... and is attached to GSM modem.. so the microcontroller is attached to internet through GPRS, by using AT commands in microcontroller. i saw this type of connection...
network a pic mircocontroller
very simple...
using Ethernet..
