How can connect serial port usb adapter with PC using C
lingaraj
Newbie level 1
chennai
Hello friends....
I have to connect 89c52 micro controller with PC using serial port to usb adapter. Now i can saw the received data in hyper terminal mode but How can i store received data in PC as a file anybody can help me?
i want program in C language... Anybody have source code means please send me.
fernando_castro
Campo Grande, Mato Grosso do Sul, Brasil
Hi lingaraj,
Are you familiar to C? Windows or Linux?
There are few ways of doing it. In one of them, your C program will have to handle the entire communication with your device, replacing the Hyper Terminal. In other words, your C program will do what hyper terminal does. Then you'll be able to store whatever your device send to PC.
The website link eXnol post is a good start. First, answer the questions so I can found out how to help you.
Regards
nandhu015
Advanced Member level 5
India
For storing data in computer you need to write a small application.
You can write that application with VB, VC or any other language.
I would suggest delphi.
horace1
Norwich, UK
if you are planning to use Visual Studio or one of the free Visual Express editions such as Visual Express C++, C# or VB they come with a SerialPort component. Open the Toolbox and look under Components. SerialPort allows you to send and receive characters via a serial COM port (including USB to serial converters)
milind.a.kulkarni
Advanced Member level 3
Bangalore
On the hyper terminal it self have one option to capture log....that also you can use to store the data that you read.....it is there on the top tab.... Similary hyper teminal there is freeware called as teraterm which is also good and come with same facility
Good Luck
eziggurat
Full Member level 6
look at this post for C# solution. https://www.edaboard.com/threads/235185/ Much quicker to write an application in C# compare to C or C++ in my opinion.
To write into a file use TextWriter or StreamWriter. There are plenty of examples in the internet. If you come into problems with cross-thread, invoke is the solution just in case you stumble into this problem with C# and if decided to use C#.
