Hello all,
I have question about PCB preference to route a signal which come from a sensor. The sensor have two wires for each detector's cell (IR photoconductive sensor with 8 independant cells : means that each cell have two wires); one of this lead must be connected to the ground of my amplifier board, and the other one is the signal connected to the input of the single ended input of the preamp. I'm wondering what is the best way to minimize the noise and common loop. Does the ground plane permit to minimize the ground loop ? (since it reduces the inductive and resistive effect) ? or is it better to have two wire (pcb tracks) on the board and then connect in one point to GND plane ?
I suppose I will have more crosstalk with a common ground plane, but I also don't want to have loop effect with a pair of wire (with one which is the ground).
See the attached file.
regards.
