onemilimeter
Member level 3
Would someone pls advise how AI (e.g. neural network, fuzzy logic, genetic algorithm, etc) can be applied in power electronics research? Thanks.
Can you provide more details on the 3rd item? Thankslovebug said:the areas are as follows
3>harmonics reduction in inverters
Thanks a lot lovebug. Do you have any article or IEEE paper on the subject you mentioned? I would very much appreciate if you could share some of them with me. Many thanks.lovebug said:suppose we want to reduce 3rd and 7th using genetics algorithm
then we define some function which will be based on the harmonics values of these 3rd and 7th harmonics now we have to minimize this function.
so what we do we have the parameters of the different waves(from which we want to reduce harmonics),which we define initially now we test these wave form for the above function.
and repeat these processes by having new waveform by the crossover and mutation
until we have desired solution
