it depends... relay will have 2 states. Nornally open and nornally closed.
so device is connected to nornally closed pin because when you need it to be connected you change over the switch, and when you dont need you bring back relay to nornally open state. So it is nothing but a switch that acts as ON and OFF switch.
---------- Post added at 20:29 ---------- Previous post was at 20:27 ----------
if you talk of relay connecting to controller then you need a driver for that and the driver you can use is ULN2003 or ULN2803. connect port pin of controller to input pin and output of ULN to relay.
It depends on the relay you're using. There are relays where, when you power the coil, 4 or 5 or even more loads can be switched on and switched off when power is removed. However, this means they'd all be powered on/off together and you won't have individual control - for this, you'd need to use separate relays. The most common relays you will find will allow you to control 1 or 2 loads at a time.
