[SOLVED] Hold doesn't depend on Time period of clock
skrishneogg
Newbie level 5
Delay of C_x = t_combi_min, t_combi_max
Delay of buffer X = t_min, t_max
Time taken for clock to propagate from clock port to CP pin of FF_launch = Launch latency = Latency_launch
Time taken for clock to propagate from clock port to CP pin of FF_capture = Capture latency = Latency_capture
Flat OCV effect delay of cell = t_ocv
Let us take this circuit as an example.
X-X------X|----------X-------[FF_launch]----------(Cx)-----(Cx)
(common)|--| |
|---------X-------X-------[FF_capture]-------|
Latency_launch_max = 4*t_max + 4*t_ocv; Latency_lauch_min = 4*t_min - 4*t_ocv
Latency_capture_max = 5*t_max + 5*t_ocv; Latency_lauch_min = 5*t_min - 5*t_ocv
t_data_max = 2*t_combi_max; t_data_min = 2*t_combi_min
Setup analysis (worst case, pessimistic)
1. Capture clock arriving much earlier than the launch clock
2. Maximum Combinational cell delay / data delay
Required time = T_clock + Latency_capture_min - t_setup
Arrival time = Latency_launch_max + t_data_max
setup_slack_extreme_pessimistic = T_clock - t_data_max - t_setup - [Latency_launch_max - Latency_capture_min] = Required time - Arrival time
Focus your attention on the first three X cells; they are common to both Launch and Capture paths; they cannot behave slow to launch path and fast to capture path!
Even if we are extremely pessimistic, we cannot rule out this common path pessimism.
==> Let us remove the pessimism involved with the common path.
cppr = Common Path Pessimism Removal = 3*t_max + 3*t_ocv - [ 3*t_min - 3*t_ocv] = 3*[t_max - t_min + 2*t_ocv]
setup_slack_pessimistic = T - t_data_max - t_setup - [Latency_launch_max - Latency_capture_min] + cppr
Hold analysis (worst case, pessimistic)
If we assume there is no setup violation. If data has to be captured by the FF_capture, the data has to be available till Required time. In this the worst case is that,
1. Capture path is slow and launch is fast
2. Combinational delay is minimum
Note: there is no dependency of time period of clock.
Required time = Latency_capture_max + t_hold
Arrival time = Latency_launch_min + t_combi_min
hold_slack_extreme_pessimistic = Required time - Arrival time + ccpr
Uncertainty
Uncertainty is always taken care in the Required time.
Required time setup with uncertainty = T + Latency_capture_min - t_setup - t_uncertain
Required time hold with uncertainty = Latency_capture_max + t_hold + t_uncertain
Hence, hold violation cannot be fixed by changing the frequency.
"limits like fear are just an illusion"
