siongboon said:Can I generally say that the cable is not dependent on the
amount of power delivered to the load,
but is only dependent on the current traveling through it?
Thank you very much for your guidance.
siongboon said:Does using a higher voltage supply means we can use a thinner wire/cable?
Thanks.
