casemod
Member level 1
- Joined
- Sep 21, 2013
- Messages
- 34
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Activity points
- 1,618
Hi all,
I have a backup system that operates at 450VDC.
During Battery/Backup operation, the accessories operate from the main battery pack, however, for efficiency reasons I need to switch over to the rectified DC BUS when AC is available.
The Battery Backup has a DC voltage of 450V. The Rectified DC Bus is just rectified 240VAC (0-340V @ 100Hz).
What would be the simplest solution to cut the battery power and force the devices to draw power from the rectified AC line instead? I Though perhaps a couple of IGBT's, but I need to avoid the current to flow from the battery to the rectified input.
Any ideas welcome
Right, seems I cant edit the first topic.
Just to simplify what I need is a switch over system that feeds the load either from the 450V or from the rectified AC supply.
Any ideas welcome
