Joeisi
Member level 1
Hello,
I am currently designing a electronic design that requires an Optocoupler connected to a 20 Vrms-400 Vrms AC voltage source. It should be designed to accept a large range of voltages. I was currently thinking about how to current limit the current going into the optocouplers LED. The datasheet of the optocoupler I am thinking of using can be found here: https://www.vishay.com/docs/83653/ild620.pdf
How would I go about current limiting the current going into this optocoupler in a manner that is both small in footprint, and also doesn't cost much? I am currently lost on how to go about this at the moment so any ideas would be greatly appreciated. If there is a different style of optocoupler or IC or such I could use I am completely open to it. However, isolation must be present somewhere in the design.
Thanks in advance.
Thanks in advance.
