memarian
Full Member level 5
- Joined
- Aug 11, 2004
- Messages
- 256
- Helped
- 57
- Reputation
- 114
- Reaction score
- 34
- Trophy points
- 1,308
- Activity points
- 2,008
High Voltage Fan Control ( High Voltage Spikes,High Reliability)
Hello,
I'm building a Fan Control Circuit for controlling the speed of a 380V Fan.(380V RMS, ~540V Peak-max 150W) using a microcontroller.
My main circuit is something similar to this FreeScale Application note : https://cache.freescale.com/files/microcontrollers/doc/app_note/AN3471.pdf
In my circuit, I have a different microcontroller, Optotriac and Triac. I can select the optotriac between MOC3082 or IL4208 (Both 800V).My main Triac will be BTA208X-1000 (1kv).
These components are currently used in our circuits and already available, so using them can be cost effective and more preferable than a new component unless we have to.
My Main problem is : This circuit will be used in an industrial place with working welding machines. Because of the effects of welding machines on main 3-Phase AC POWER, there is some spikes up to 1kv on AC-Line. I'm not sure if the optotriac can take this for long period and i couldn't find any 1kv optotriac. How can i protect the optotriac against these spikes? How can i increase my circuit's reliability?
Hello,
