High Voltage DC measurment
saumya_85
Full Member level 1
INDIA
I want measure the HID lamp voltage and current using existing micro controller ( No ADC internal) .. Also let me know Which is the best Opamp for this application :
HID lamps require a high voltage for ignition (3 to 4 kV typical, >20 kV if the lamp is hot), current limitation during warm-up, and a constant power while running. then form 20V to 140 V AC will be present at the output. Current will vary .25A to 10A depend upon lamp wattage.
Need circuit help....
