High inductance = high reactance. If an alternate path with lower reactance exists, the signal will follow the path with lower reactance. For a basic understanding, consider resistance same as reactance. Alternate path means another parallel connection. If two resistors are there in parallel, more current will flow via the resistor with lower resistance.
No. Frequency does not affect inductance and reactance does not change inductance.
I was trying to deal with the OP's misconceptions .
