high side mosfet driving with IR2110 - problem
jegandren
Junior Member level 3
Dear all,
Attached is a circuit to drive a single high side driver, the circuit works fine when the load is not connected to the parallel capacitor (470uF/400V). but when the capacitor is connected in parallel to the load the IR2110 is burnt,
can any one advise on this.
Many thanks
A freewheeling diode must be present to suppress negative output voltages when opening the switch. Furthermore, without a low-side switch, there must be at least a resistive load to charge the bootstrap capacitor.
I also don't see the purpose of the diode-inductor series circuit.
Re: high side mosfet driving
hi,
I have attached the the circuit with the free wheeling diode.... please ignore the diode - inductor series circuit...
do i need to add a lowside switch in order to make it work, because here i dont really need the low side swicth..
Without a low-side switch, the circuit can only be started with zero output voltage. It needs some auxilary circuit to charge the bootstrap capacitor. I think, IRF has specials drivers for single high-side switches.
As for single side driver, i think if i use IR2117 single side driver, would that solve my problem.
if your duty cycle is less than 70%, use an isolation transformer instead
u mean a drive trafo circuit , to drive the high side mosfet
Added after 1 hours 19 minutes:
Dear All,
I have attached some changes, because as earlier the bootstrap capacitor is not charged..
At the beginning of the initial cycle during startup, the bottom-side MOSFET switch is turned on. This pulls the Vs pin to ground, which charges up the bootstrap capacitor to through bootstrap diode .
When the high-side driver is enabled during the next half cycle, the driver can turn on the high-side mosfet, and the Vs pin will rise up to VIN (0-300 V) .
Then the cycle repeats itself—high mosfet is switched off, bottom mosfet turned back on, the Vs pin is pulled down to ground, and bootstrap capacitor is recharged.
Yes use a driver transformer for the high side and use a totempole on the low side driver, by the way what is your switching frequency?
This can work, but the IRF level shifting drivers surely have superior switching behaviour. I guess, you never used these devices.
Dear All,
I ahve noticed the circuit that i have attached works fine when the 470uF / 450 V capacitor is not added.
when i add the 470uF/450 V capacitor i have noticed that the Vin most to most goes up to 20V and beyond that the IR2110 burns.
Can anyone advise on this
I don't understand, which voltage is meant exactly. Generally, there may be a circuit layout problem. Do you have any measures to keep the inductor current within acceptables limits during turn-on.
If you mean the input voltage ripple: There must be of course an effective bypass capacitor!
As another point, I fear that the output inductance is at least one order of magnitude too low! 22 uH means maximum of 13.5 A/us current slope at the output inductor. Would require MHz switching frequency for moderate ripple currents.
If you originally intended to operate the inductor with non-continuous current flow, you can't use a low side switch and need a different MOSFET driver or an auxilary circuit for the high side driver supply.
very sorry for not stating it clearly...
The Vin that i meant is actually the high voltage ( 0 - 300V)
I notice if i don't add the 470uf /450V capacitor, then the circuit works fine, but when i add the 470uf/450V capacitor and increase the high voltage starting from 0V when i increase up almost 20V the circuit works fine, switching is ok but when i increase the high voltage to 20V and above the IR2110 IC burns ...and i have changed few IC's due to this.
Added after 2 hours 16 minutes:
Actually can you please explain on why i can't use alow side switch and need a different MOSFET driver.
so u mean to say that switching at 20Khz frequency is not enough for a 22uH inductor.
