Jun 16, 2005 #1 T ThomasLee Newbie level 5 Joined Sep 14, 2004 Messages 10 Helped 4 Reputation 8 Reaction score 2 Trophy points 1,283 Activity points 81 Hello @ all! I am searching for references (papers, books) for amplifiers with similar specs to these: 10dBm input p1dB 8dB gain 20-200 MHz 50 Ohm differential input and 50 Ohm single ended output 5V supply Noise Figure < 10 dB Do you can help me with that? I am thinking of OPAmp techniques but the input linearity is very high... Regards, Lee
Jun 18, 2005 #2 M mitgrace Full Member level 6 Joined May 8, 2004 Messages 367 Helped 6 Reputation 12 Reaction score 2 Trophy points 1,298 Activity points 2,526 hello , what is application for your product , Because the input power is very high , and the BW is 20~200MHZ is very difficult to implement . we have do the op work on 30MHZ . like AD9875 , but it is a little different with your specific
