G
tests on a dc motor
Hi all
I need help in the following situation. I need to inject a high frequency (kHz) signal in a DC motor while working. So, simultaneously we will have in the motor winding the DC current from the power source, and the AC signal that came from an AC source.
What are your suggestions? I thinking to use a toroid with its primary side connected to the AC source, while the secondary is connected in series with the motor winding. Is this a good solution?
Best regards
Pendragon
Hi all
Best regards
Pendragon
