220vdc-220vac power inverter
Hi to all !
I will put this as simple as i can but please give me some suggestions from the "real life"
and please be so kind to give answer to all questions becuse it's really importent to me. Thank you in advance !
Idea:
DC source - 220 V
DC amperage - 100 mA
DC source is something like battery but i dont know if i can look this thru AmperH.
Goal:
- To power 1KW (AC 220 ~ 50 HZ euro scale ) hair dryer for one hour.
- looking for cheap electronic solution
Additional options:
- use of microcontrollers
Questions:
I know this idea is a "bit" abstract but this is just idea.
1.) DC source -- some regulator -- DC\AC converter. --> hair dryer ? This is just idea, please give me your suggestions !
2.) How to organize power needs to reach the goal part
3.) Which hardware solutions can i use to get closer to the goal part
4.) How much AC amperage can i produce with 220 ~ 100mA DC ( with converters, regulators) ?
5.) How much DC voltage and DC amperage do i need (at the source and before conversion) to get 4,54 A at the hair dryer if the DC\AC inverter is on 70% effec. ?
6.) If i can encrease voltage to 500V DC but if the power is still low, can i use some IGBT like two phase converter ?
Calculations for hair dryer option:
t = 1kW/1000W --> 1 hour of work. I = 1000w/220 = 4,54 A
Please be so kind and give me your suggestions and please give me answer to all questions so i can understand the whole concept.
Mark
