RohanDey
Member level 2
Hello,
I am trying to design a voltage regulator with the following spec:
Input - 16VDC unregulated
Output - 12VDC, 1.5 Amp and 9VDC, 1.5 Amp (either one output will be used at a time not both)
I think a linear regulator will not work good for me at full load, so I would like some help in designing a switching regulator.
I have seen the IC LM2676 with which my requirement can be fulfilled, but LM2676 does not have a 9V variant. It only has for 3.3V, 5V, and 12V
Can someone please suggest which IC I should use or any other design methodologies to achieve the above.
Thanks..
Thanks..
