najmuus
Junior Member level 1
Hi
1.HOW MANY O/P PADS CAN BE SUPPORTED BY PAD RING WITH A 10 LAMBDA WIDE POWER LINE .
2.A CHIP CORE IS 3000LAMBDA X 2500 LAMBDA AND REQUIRES 0.8 amps .IT NEEDS 18 SIGNAL I/P PADS AND 19 O/P PADS .
HOW MANY Vdd and Vss PADS ARE REQUIRED ASSUMING A 12 LAMBDA POWER RING ? WILL THE TOTAL CHIP SIZE BE LIMITED BY THE CHIP CORE OR BY THE PAD RING
please i required the solution
