BENOIT
Member level 5
hilosystems all01 programmer schematic
Hello,
I am looking for the software of the DMT-01 digitel and memory ics tester from Hilosystems.
Unit has 3 6821 IC's and several TTL and transistors inside box. Some have 1987 date codes.
My request is more described here : **broken link removed**
This tester is made of a 8-bit ISA Card CSA-01 which is similar but not exactly
the same than the all02.
the sofware is perhaps a simple file called dmt01.exe
tryed the softwares ALL02, ALL01, and some ICT301 and ICT302 from Sunshine
without success.
The closest to work was the ICT302 but the ports are assigned to different functions and pins etc.
There are several 8255 and 6821 inside the all-02.
If I had schematic of all02 it may be possible to modify DMT-01 but too much work anyway.
thanks for any help,
Best regards,
Matthieu
Hello,
without success.
Best regards,
Matthieu
