hfss_Driven terminal or Driven Modal
kyungseom
Newbie level 6
Hello.
I want to find out what type of solution do i have to use for the hfss simulation
There are open terminals in my design then do i have to use Driven Modal as a solution type???
myemworld
Junior Member level 2
You can use both all the time. Driven Terminal is easier to set up for all conditions, so unless you really want modal s-parameter data, I suggest you use driven terminal. Driven Modal for waveguides may give better results for some cases.
Joline.
