[SOLVED] HFSS version 9.2 Object intersects
Radike
Member level 3
I designed a HFSS filter and it containes Vias as well. These Vias intersects my dielectric. When I try to simulate it gives an error saying dielectric and the vias are intersecting. Can somebody help me how to remove this error. In HFSS 11 there is a option for this. But I couldnt find it in HFSS 9.2.
Can somebody help regarding this?
Thanks alot!!!
you need to pick all objects that are intersecting then perform the correct boolean operation. after you select the two objects you should be able to right click and select boolean...subtract so on..
