I design 2 patch antenna on pcb, each of them there is a port, when i look on rediation pattern result, is the radiation pattern belong to both of them ? how i can see only the radiation pattern of one antenna ?
Set the magnitude of the excitation (voltage or power) of the port you want to a non-zero value, and set the rest to 0. Then view the radiation pattern.
