Arash_S
Hi everyone,
I need some help with ANSYS HFSS software as I have little experience in this simulation tool.
I am trying to compare the absorption or radiation performance of different boundary conditions such as Perfectly Matched Layer (PML), first-order Absorbing Boundary Condition (ABC) and Boundary Internal Equation (IE).
I have a document from ANSYS that shows the return loss of two different radiation boundaries at different incident angles. They have used a Pyramidal horn antenna as a source of radiation and observed the reflection from the radiation boundaries (here is the link to this document: http://www.ece.uprm.edu/~rafaelr/in...ainee/ANSYS_HFSS_Antenna_L04_0_Boundaries.pdf).
So far I have simulated the Pyramidal horn antenna inside the PML boundary and observed the Electric and Magnetic field propagation toward the PML. I can see that there are some reflection as I animate the simulation over different phases but I don’t know how to get graphical results of the reflection vs antenna incident angle. :sad:
I would like to know if anyone knows how to setup this test so that we can observe the reflection of the radiation boundaries at different incident angles.
Thank you
Thank you
