I'm trying to simulate the magnetic field between two LC circuits a distance Z apart and find out the Q and S parameters of the system so I can see the efficiency and whatnot.
I'm new to HFSS so it came with this thing called the "Antenna Design Kit" and I was able to generate a model of a helical antenna coil and it has a ground plane and whatnot.
I was able to simulate the magnetic field around it but my actual work requires me to use an LC circuit so that I do not radiate E field (just want H field).
My question is, is it the same thing? Is simulating the magnetic field of a helical antenna with a ground plane and coax input the same thing as simulating the magnetic field of the LC lumped helical coil and capacitor??
If so, I can just use the antenna design kit and duplicate two of the generated coils and just run the simulation.
But if they're not the same, can anyone suggest a way of going about this? My LC circuit will have a voltage +/- input to it so its kinda like an electronics circuit really, not something HFSS is for but I was wondering how I can do it in HFSS because no circuit simulators can simulate the EM fields of lumped components (that I know of).
Thanks!
