hai im designing circular patch with coaxial feed........i have the following error as the probe and inner conductor of the coax are intersected.how to correct it?
I'm not sure what you are describing. Wouldn't the probe be the inner conductor of the coax? If not, can't you just ensure that the objects don't intersect?
my design is the circular patch and cylinder as the substrate.If i draw the coaxial feed means,i drawn 2 cylinders at the bottom and 1 on the top.the top is intersect with substrate.this is my problem
