hi
I attach my project, this is 90 degrees hybrit coupler.
My problem is to change the length of the coupler. I drew the model and results are not satisfying, so I want to change the lengths of the some parts. However I united all small parts, and I cannot change parts now. Can I de-unite items? Do I have to draw them again?
One more question, using duplicate makes life easier, but when I do not want changing one part to affect duplicate part, what should I do?
thanks.
You should define some project variables and create the structure using them like L for some length , R for some radius and so on. Not only will you be able to modify structures easily but also you can perform parametric sweeps and optimizations easily with such an approach. Consult the HFSS online help for more details.
thanks for your answer
what about uniting? is it necessary?
another problem is duplication. should I duplicate? how can I change only one of the duplicated items?
thanks.
You can perform all boolean operations after defining variables. You will get the structure as you want provided the values of parameters do not become illegal i.e supp the absolute value of some length turns out negative. So if you can assure a legal structure with the range of parameters used, you can always use this approach. I infact use this to enable me to quickly change the geometries. May be you can add some independent steps if you need to apply changes to only part or something like that
In order to undo the unite operation right click the (united) object and click "Delete Last Operation". This will create back the original objects. Then I suggest that you wil parameterize the length.
Instead of duplicating use good old fashioned "Copy-Paste". Just make sure that when you are pasting you are in the global coordinate system.
In order to undo the unite operation right click the (united) object (form the model tree) and click "Delete Last Operation". This will create back the original objects. Then I suggest that you wil parameterize the length.
I will use copy-paste as you suggest, because duplication may cause problem. I have to consider all the bounds.
secondly, if my coupler was only straight lines, parametrizing would be easier. however, to parametrize my original one is so complicated. therefore, I decided to use straight lines and parametrize these lines, then I will use that length to build compact form.
thanks all.
about de-unite
I found how to undo unite even after some changes and save operations.
simply delete "unite" segment on the list and all parts form united one object will be de-united.
my two cents:
the coupler in your design have some symmetry propeties we can use. it should be helpful to build up the parametric studying model. Build up a S-shape element(unite 1 rectangle and two segments of arc), then duplicate and move, unite necessay part and subtrace unnecessary part. Wish you can get what I am saying.
PS, is there any difference about copy + paste and duplicate + move?
my two cents:
I am about to complete my study on coupler, next , I will design a birdcage coil.
anyways, thank you for your advice. for your question, there is a major difference between two: when you duplicate and change a property of one element, other will change immediately.
however, when you copy and paste, they are independent after all.
you may use both for different implementations.
