Hfss Non-Manifold fractal antenna
Eng_AboEzn
Newbie level 1
hello everyone
son i have designed a fractal antenna with my HFSSv13, but when validate it it keeps saying "Non-manifold vertices found for part Patch". I've tried to upgrade it to v15 but didn't help.
And I try to use Heal from Modeler, the problem is only in the vertices that links the left patch (of the first iteration) with base patch and the right patch, so its only two vertices.
I've tried to use the Unit from Modeler, but the same issue
  • Sim_Fractal - Copy_1.zip
This is a modeler error.
HFSS mesh can deal with it if you tell to skip modeler check going to:
modeler/validation setting/
Solution : Delete the Unite operation for the Patch object. Move the Patch 1 and Patch 2 objects and assign Perfect E
