konrad_gom
Junior Member level 1
Does High Frequency Normally Closed Switch exists? It should work up to 3GHz and should have small SMD package.
Explanation what I need:
![Relay.png Relay.png](https://www.edaboard.com/data/attachments/60/60066-85d9b57af173a3bd3305f34110f25acf.jpg)
It should be normally closed switch, which without power supply is closed to one position. So two of them should works as a bypass (with low losses). After power supply comes, switch should switch to second position, to some electronic circuit.
Does such element exists? If yes, please some example.
Regards.
Regards.
