Qwme5
Junior Member level 2
- Joined
- Jan 19, 2011
- Messages
- 23
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,444
Superposition theorem states to replace all sources, except one, with equivalent resistance. Then finally add up them to get the total value. So where are you facing problem in this.?
Are you sure? What is the "equivalent resistance" of a voltage source?
Yes, I am sure. But I would like to make a slight modification in my statement. It should be equivalent impedance, not resistance (to be more perfect).
And the equivalent impedance of a Voltage source is 0 ohm, i.e. it should be replaced with a short circuit.
OK - so you mean not really an "equivalent" resistor but simply the internal source impedance of the source, correct?
I think, this clarification is necessary - otherwise the OP (who seems to be not very experienced) will get confused.
Stop fighting im my post , i need help if u could help me i will be thankful otherwise plz dont reply TQ.
As a first step, remove the 1.2 amp source and the 1.2Ω resistor and calculate I1 and I2
