help with etmp4 - urgent
vess
Newbie level 3
Newbie level 3
I tried to run this command:
~/ns-allinone-2.34/ns-2.34/v1$ ./etmp4 -p -0 sd_1 rd_1 st_a01 a01.mp4 a01e
*** loss_a01e.txt ***: percentage of lost [frames|packets]
column 1: I (including H)
column 2: P
column 3: B
column 4: overall
*** delay_a01e.txt ***: jitter/delay statistics
column 1: [frame|packet] id
column 2: loss flag
column 3: end-to-end delay
column 4: sender inter [frame|packet] lag
column 5: receiver inter [frame|packet] lag
column 6: cumulative jitter [Hartanto et. al.]
*** rate_s_a01e.txt ***: sender rate
column 1: time
column 2: momentary rate [bytes/s]
column 3: cumulative rate [bytes/s]
*** rate_r_a01e.txt ***: receiver rate
column 1: time
*** glibc detected *** ./etmp4: double free or corruption (fasttop): 0x080b9b88 ***
======= Backtrace: =========
/lib/tls/i686/cmov/libc.so.6[0xb7e83b25]
/lib/tls/i686/cmov/libc.so.6(cfree+0x90)[0xb7e87590]
./etmp4[0x807b412]
./etmp4[0x807d317]
./etmp4[0x804c440]
./etmp4[0x804d7c3]
./etmp4[0x804dc1e]
/lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe0)[0xb7e2e450]
./etmp4[0x8049271]
======= Memory map: ========
08048000-080b0000 r-xp 00000000 08:01 2974088 /home/celtro/ns-allinone-2.34/ns-2.34/v1/etmp4
080b0000-080b1000 rw-p 00067000 08:01 2974088 /home/celtro/ns-allinone-2.34/ns-2.34/v1/etmp4
080b1000-080f0000 rw-p 080b1000 00:00 0 [heap]
b7a00000-b7a21000 rw-p b7a00000 00:00 0
b7a21000-b7b00000 ---p b7a21000 00:00 0
b7bbb000-b7bc5000 r-xp 00000000 08:01 65600 /lib/libgcc_s.so.1
b7bc5000-b7bc6000 rw-p 0000a000 08:01 65600 /lib/libgcc_s.so.1
b7bd4000-b7e18000 rw-p b7bd4000 00:00 0
b7e18000-b7f61000 r-xp 00000000 08:01 82947 /lib/tls/i686/cmov/libc-2.7.so
b7f61000-b7f62000 r--p 00149000 08:01 82947 /lib/tls/i686/cmov/libc-2.7.so
b7f62000-b7f64000 rw-p 0014a000 08:01 82947 /lib/tls/i686/cmov/libc-2.7.so
b7f64000-b7f67000 rw-p b7f64000 00:00 0
b7f67000-b7f8a000 r-xp 00000000 08:01 82951 /lib/tls/i686/cmov/libm-2.7.so
b7f8a000-b7f8c000 rw-p 00023000 08:01 82951 /lib/tls/i686/cmov/libm-2.7.so
b7f97000-b7f9c000 rw-p b7f97000 00:00 0
b7f9c000-b7f9d000 r-xp b7f9c000 00:00 0 [vdso]
b7f9d000-b7fb7000 r-xp 00000000 08:01 67847 /lib/ld-2.7.so
b7fb7000-b7fb9000 rw-p 00019000 08:01 67847 /lib/ld-2.7.so
bfc01000-bfc16000 rw-p bffeb000 00:00 0 [stack]
Aborted
What can be the problem?
I have the etmp4 tool and all files that needed in the same folder (v1).
Thanks.
