Hi all,
I'm planning to start the DRC, routing and LVS of a analog designed circuit. I have no experience in this field. What are the things to consider ?
What do you advise me in order to obtain a nice Layout apart of course the patience ?
Thanks in advance.
According to me try to do soem physical verification using gui for very small designs and then on u can carry on for bigger design .. So once ur comfortable with gui and that u have learned enough with . Shift to scripts.
try to look at the design rules before you start
just to get an idea
and make DRC after each part you do in the layout
just to make sure you're on the right track
try to get familiar with the tool before you start
if you have never used it before
just do a layout for an inverter or a nand for instance
know the hot keys for the normal tasks, copy, move, stretch...etc
which tool are you using..?
if you have any trouble please tell me to help in any way i can
