neazoi
Advanced Member level 6
Hello, I have build the Fig 2. load and probe from this page https://www.ab4oj.com/test/pwrmeas.html in order to measure a 1w @50R transmitter with my scope.
First I just connected a 50R load without the divider. I think (without the divider) the writer assumes a 1M scope input for the measurements, am I right? Because if the 50R scope input is used it will be paralleled with the 50R load resistors ti give 25R. Am I right?
Second, when I build the 10:1 probe (voltage divider) together with the load as shown in figure 2, gives about 2.5vpp (measured at 1M scope input). But my signal is 6.3vpp, measured at the 50R scope input alone.
What is the problem?
