A Mosfet is turned on with a voltage from its gate to source, not with a current. What voltage did you use? The drain has a load connected between it and the positive supply voltage, didn't you use a load? What voltage did you use? What load resistance? Didn't you read the datasheets for the different Mosfets?
The gate to source voltage needed by a IRFL4315 Mosfet is 3V for all of them to barely turn on or 10V for all of them to turn on well.
The gate to source voltage needed by a 2N7002 Mosfet is 1V for all of them to barely turn on or 5V for all of them to turn on well.
Some of the Mosfets turn on well with a lower voltage, maybe your 2N7002 is a very sensitive one.
