help: TSMC BJT spice model
aindejeje
Junior Member level 2
Hello.
This is my first time doing mixed-signal IC design.
Im designing a CDP on Tanner and simulate it on T-SPICE.
and got the following error:
Fatal T-SPICE : Missing model declaration for "NPN"
I guess i need a BJT model for it.
SPICE model for TSMC (prefer 0.25um technology)
Can anyone help me?
erikl
Super Moderator
Staff member
Germany
Pls. find here SPICE Model Parameters for several TSMC 0.25µ processes!
    aindejeje
aindejeje
thanks for your help.
but whats are the:
MM NON EPI
LO MTL etc
erikl
Super Moderator
Staff member
Germany
aindejeje said:
... but whats are the:
MM NON EPI
LO MTL etc
These are all different 0.25µm processes (each process option has a unique name).
But meantime I discovered the files contain just S*PICE parameters for MOSfets, not for BJTs, sorry! :cry:
You should also specify, if you need a S*PICE model for a lateral or for a vertical npn. They can be quite different.
aindejeje
erikl said:
MM NON EPI
LO MTL etc
yeah.no BJTs :cry:
karthikvenkatesh
Newbie level 2
Hi erikl,
I am Karthik.
I am trying to simulate a circuit having BJTs in spectre.
I need 0.35 micron tsmc BJT model because my need in BJT that operates at 5v. I am not sure whether it is lateral or vertical BJT i need.
erikl
Super Moderator
Staff member
Germany
karthikvenkatesh said:
Hi erikl,
I am Karthik.
Hi Karthik,
a 0.35 micron tsmc BJT model you can only get from TSMC if you sign an NDA, or through MOSIS, by a similar procedure.
You could perhaps get 'incognito' SPICE models for a similar 0.35 micron process, but the simulation results ain't necessarily identical. If you intend to produce a chip, it's a must to use the original models from the very process.
Which model is available depends on the respective PDK. A 'standard' CMOS process usually includes a vertical pnp BJT (beta ≈ 2 .. 5), sometimes additionnally a lateral pnp (beta ≈ 20 .. 50). In any case their collectors are connected to the substrate. If you need uncommitted BJTs (also npn ones), you have to select a BICMOS process.
karthikvenkatesh
Newbie level 2
Erikl,
Thanks for your comments which is very helpful.
What I did is, I browsed through MOSIS site, got IBM 0.35 micron BJT NPN model whose forward beta is 100.
My specification is beta = 20. So i changed that forward beta and used those parameters in spectre for simulation.
This BJT model is for Bandgap reference design.
Some say, dont dwelve a lot into all of the BJT model parameters. Just take the beta=20. Since the role of BJT here in bandgap is not gain oriented but just to nullify the temperature coefficient.
Thanks and regards,
Karthik
erikl
Super Moderator
Staff member
Germany
... IBM 0.35 micron BJT NPN model whose forward beta is 100.
Probably from a BICMOS process.
That's ok. Even simple diodes would work. BJTs beta > 1 achieve better accuracy, however.
Rgds, erikl.
cmos_ajay
Full Member level 2
Hello,
Can you please send me the link to the BJT NPN model . Thanks in advance.
Regards.
Erikl,
Thanks and regards,
Karthik
aadiltrikha
Newbie level 6
india
open your tsmc technology file
probably u ll be having there pmos nmos parameters
now add this line there
.model PNPDIODE D IS=1e-18 n=1
and in interconnections use the above name PNPDIODE for refernce
now for this we are having fully defined cmos models but no BJT as 3 are used here D1,2,3
so if you are not using this circuit for layout etc then just u can add this line & it will serve your purpose of BJT
i am posting full t-spice for this circuit,
.option scale=1u post
.dc VDD 0 6 1m temp 0 100 25
VDD VDD 0 DC 5
Vop Vop 0 DC 0
Von VDD Von DC 0
Vmeas1 Vmeas1 0 DC 0
Vmeas2 Vmeas2 0 DC 0
M1B Vbiasn Vbiasn Vd1 0 N_1u L=2 W=10
M2B n2 Vbiasn Vr 0 N_1u L=2 W=10
M1T vncas vncas vbiasn 0 N_1u L=2 W=10
M2T vpcas vncas n2 0 N_1u L=2 W=10
M3T n1 Vbiasp VDD VDD P_1u L=2 W=30
M4T Vbiasp Vbiasp VDD VDD P_1u L=2 W=30
M3B vncas Vpcas n1 VDD P_1u L=2 W=30
M4B Vpcas Vpcas Vbiasp VDD P_1u L=2 W=30
M5T n3 vbiasp VDD VDD P_1u L=2 W=30
M5B Vref vpcas n3 VDD P_1u L=2 W=30
RL Vref vd3 489k TC1=0.002
Rb Vr vd2 52k TC1=0.002
D1 Vd1 0 PNPDIODE
D2 vd2 0 PNPDIODE 8
D3 vd3 0 PNPDIODE 8
** Start-up Circuit
MSU1 Vsur Vbiasp VDD VDD P_1u L=2 W=30
MSU2 Vncas Vsur Vpcas VDD P_1u L=2 W=30
MSU3 Vsur Vsur ns1 0 N_1u L=10 W=10
MSU4 ns1 ns1 ns2 0 N_1u L=10 W=10
MSU5 ns2 ns2 0 0 N_1u L=10 W=10
.include tsmccmos_models.txt
.end
Hope it ll be helpfull :) :roll:
aadiltrikha
Newbie level 6
india
lets see the image & work out example here View attachment 70821
VDD VDD 0 DC 5
Vop Vop 0 DC 0
Von VDD Von DC 0
D1 Vd1 0 PNPDIODE
D2 vd2 0 PNPDIODE 8
D3 vd3 0 PNPDIODE 8
** Start-up Circuit
.end
---------- Post added at 16:50 ---------- Previous post was at 16:35 ----------
i have defined here in which n=1 just defines level of bjt model i.e. =1 so only is that is breaking point of bjt i am mentioning here which you can vary,.
also try to not be completly dependent on model technology files of companies, like sumtimes u want to implement your design <<innovatively>> or tech file are not having that parameter value,, so always just put .model command , edit , set level, make ,edit or add parameters accordingly ..
the above mentioned tsmc models is for 1micron tsmc technolgy for that BJT with IS=1e-18 i have used ,, but for 0.25u which u are using definitly value will be different , which is headache :) beacuse when i added resitor RL Vref vd3 489k TC1=0.002 TC temp coefficient was very hard to find ,, so process goes like that ,,
also switching to bicmos is very helpfull :)
