help to programm pic 18f2550
ristici
hi,
i have try to program pic 18f2550 with winpic800 and this programmer
http://aymatt.blog.com/2010/08/03/pickit-2-clone/
but software recognize the pic only when vdd is 3-4.3v, then reading work but programming not. when vdd is more as 4.3v then reading and programming not work
what can be the problem?
what is best diy hardware that work with high voltage programming for pic18f2550 ? and what software to use?
best regards
voltage on c3 is 11,9v
best regards
now is 18f2550 programmed with bootloader for pickit2 , but now is problem that pc not recognize the interface!
can someone to tell me configuration bits ?
thanks guys, i have found where is error...mcu internal voltage regulator is damaged, new mcu and all work
best regards
