Hi!
I'm new to electronics and are about to use the Murata's IRS-B210ST01 PIR pyroelectric sensor. Provided to the sensor is schematics of typical application circuit for human detection:
or
Shortly the circuit is a filter/decoupling, a load resistor, a non-inverting amp with gain around 100, an ac-coupled biased inverting amp with gain 100 and a window comparator and after that is not of interest..
However I've some questions regarding it:
1: Why are the window comparator's hi and low voltage reference levels not equal level from the midpoint between GND and Vcc? Is it possible that they have forgot a 260k resistor? It makes no sense as it is. In other words if Vcc is 3V why are not 1.5V used as midlevel (equal to the offset of the output signal from the inverting amp) and as an example hi level is 0.3V above and low 0.3V below?
2: What are the capacitors in the feedback of the op amps used for? Stabilization or some kind of filtering?
3: What purpose do the diode in the first amplifier have?
4: Why do they use capacitors between the interting and non-inverting inputs of the op amps??
5: Why do they use two resistors of equal value on both the non-inverting and the inverting inputs of the op amps?
I need answers quick and therefore I post here because I believe that it will take longer to mail the company.
And some questions regarding simulation of the sensor that is not as important:
is there any PSPICE simulation models of PIR sensors using dual elements available? I've searched for it but I can't find any..
I've tried to make a simple model my self using the equivalent circuit but because there is almost no specifications provided to the sensor I find it not that easy. What can typical values be of the equivalent circuit of a ceramic pyroelectric sensor? I believe the parallel resistance is 1G-10Gohm but what can the parallel capacitance be? How to choose an appropriate FET for simulation? How is the equivalent circuit affected of the sensor using two sensor elements being connected together? Either PSpice or Multisim like two current sources to be connected in series.. Is it correct to use two in parallel and the current from either is the differences (between the two in series in the real circuit) where one generates positive pulses and the other one negative pulses?
I really appreciate answers
thanks!
