iamkamalrandhawa
Hello Freinds i need a way to extract dell exe bios. I want TO reprogramme Bios on some dell laptop because their Bios Is corrupted. Thanx In advance.
I'm not sure exactly what you want, but I'm guessing that you cannot boot the laptop even into BIOS mode because the BIOS is corrupt.
Which laptop?
Most laptops (actually, most BIOSs) have an emergency recovery mode whereby it is possible to force a BIOS update even if the system cannot boot.
Try this:
Download the required BIOS file; let's call it x.exe
Extract the HDR file from the x.exe with: "x.exe -writehdrfile". This will give a file x.hdr
Copy x.hdr to a formatted diskette, perhaps on a USB-diskette (might even work on a pen drive)
Rename x.hdr according to the list below
Unplug the adapter and remove the battery from the laptop
Hold "END" down on the keyboard while you plugin the Adapter
The battery light should come on red
Release "END" - the laptop power should up
Wait while the diskette is read, this might take some time (you'll hear it)
The laptop should shut down or restart itself
Job done!
Dell Latitude D410 : VENI???.BIN, VENI???.HDR, VENI???.HDC, VEN????.BIN, VEN????.HDR
Dell Latitude D420 : CRO????.bin, CRO????.hdr, CRO????.hdc, D420???.bin, D420???.hdr
Dell Latitude D430 : CAR????.bin, CAR????.hdr, CAR????.hdc, D430???.bin, D430???.hdr
Dell Latitude D610 : AZED???.bin, AZED???.hdr, AZED???.hdc, AZE????.bin, AZE????.hdr
Dell Latitude D620 : TRAV???.bin, TRAV???.hdr, TRAV???.hdc, D620???.bin, D620???.hdr
Dell Latitude D630 : BRIS???.bin, BRIS???.hdr, BRIS???.hdc, D630???.bin, D630???.hdr
Dell Latitude E4300 : LOLA???.bin, LOLA???.hdr, LOLA???.hdc, E4300??.bin, E4300??.hdr
Dell Latitude E6400 : RSH????.bin, RSH????.hdr, RSH????.hdc, E6400??.bin, E6400??.hdr
If your laptop is not listed, try google.
You have not said what the laptop model is.
The instructions that I gave are for using the emergency recovery file; I have no idea if you can simply write that file directly to the chip. What file size did you get - did it match the chip's size?
Can you verify that the file has been written correctly to the chip with your programmer? Did you use SPI, or pull the chip from the board and plug into your programmer?
