[SOLVED] [Help]Stuck in vb coding
sk8ter87
Member level 3
Malaysia
Hi guyz..i'm new to vb..
i'm doing vb program that that take input from the keyboard from pc then sent to pic micro controller using serial port and then perform the action that been requested.
I tried do the coding,but not working and i really stuck now..
hope you guyz can help me.
Here i'm attaching the vb code:
  • vb code.txt
I guess that you have missed data sending part through serial port something like below
'Sender
Private Sub SendData(strdata as String)
MSComm1.output = strdata
End Sub
check data sending routine again
regards
bassa
Thanks bassa..Manage to run the program..Forget to put the part that you mention..:D
