library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
use ieee.math_real.all ;
entity signal_mapping1 is
port( Clock : in std_logic;
Reset : in std_logic;
Enable : in std_logic;
in_I : in std_logic;
in_Q : in std_logic;
out_I: out REAL ;
out_Q: out REAL
end signal_mapping1;
architecture Behav of signal_mapping1 is
type ROM_Array is array (0 to 15)
of real;
constant Content: ROM_Array := (
0 => 1.0, -- Suppose ROM has
1 => 0.0, -- prestored value
2 => 0.70710_67811_86547_52440, -- like this table
3 => 0.70710_67811_86547_52440, --
4 => 0.0, --
5 => 1.0, --
6 => -0.70710_67811_86547_52440, --
7 => 0.70710_67811_86547_52440, --
8 => -1.0, --
9 => 0.0, --
10 => -0.70710_67811_86547_52440, --
11 => -0.70710_67811_86547_52440, --
12 => 0.0, --
13 => -1.0, --
14 => 0.70710_67811_86547_52440,
15=> -0.70710_67811_86547_52440,
OTHERS => 505.0 --
signal address_i:integer := 0;
signal address_q:integer := 1;
begin
process(Clock, Reset)
begin
if( Reset = '1' ) then
out_i <= Content(0);
out_q <= Content(1);
elsif( Clock'event and Clock = '1' ) then
if Enable = '1' then
if(in_q='0' and in_i='0' ) then
out_q <= Content(address_q+2);
out_i <= Content(address_i + 2);
address_i <= address_i+2;
address_q <= address_q+2;
elsif(in_q='1' and in_i='0' ) then
out_q <= Content(address_q+4);
out_i <= Content(address_i + 4);
address_i <= address_i+4;
address_q <= address_q+4;
elsif(in_q='0' and in_i='1' ) then
out_q <= Content(address_q+6);
out_i <= Content(address_i + 6);
address_i <= address_i+6;
address_q <= address_q+6;
elsif(in_q='1' and in_i='1' ) then
out_q <= Content(address_q+8);
out_i <= Content(address_i + 8);
address_i <= address_i+8;
address_q <= address_q+8;
end if;
else
out_q <= 505.0;
out_i <= 505.0;
end if;
end if;
end process;
end Behav;
--------------------------------------------------------------tb-------------------
library ieee ;
entity signal_mapping_tb is
end signal_mapping_tb ;
architecture signal_mapping_tb_arc of signal_mapping_tb is
component signal_mapping1 is
out_I: out REAL ;
out_Q: out REAL
end component;
signal enable_tb : std_logic;
signal clock_tb : std_logic :='1';
signal reset_tb : std_logic;
signal in_i_tb : std_logic;
signal in_q_tb : std_logic;
signal out_i_tb :real;
signal out_q_tb:real ;
constant clk_time: time := 50 ns;
begin
UUT : signal_mapping1
port map (
enable => enable_tb,
CLOCK => clock_tb,
reset => reset_tb,
in_i => in_i_tb,
in_q => in_q_tb ,
out_i => out_i_tb,
out_q => out_q_tb
clock_proc: process
begin
clock_tb <= not(clock_tb) ;
wait for clk_time;
end process clock_proc;
reset_in:PROCESS
BEGIN
reset_tb<= '1';
WAIT FOR 10 ns;
reset_tb <= '0';
WAIT;
END PROCESS reset_in;
enable_in:PROCESS
BEGIN
enable_tb<= '1';
WAIT FOR 10 ns;
enable_tb <= '0';
WAIT;
END PROCESS enable_in;
in_q_tb <= '0','1' after 200 ns,'0' after 400 ns,'1' after 600 ns
,'1' after 800 ns,'0' after 1000 ns,'1' after 1200 ns,'0' after 1400 ns,'1' after 1600 ns
,'1' after 1800 ns,'0' after 2000 ns;
in_i_tb <= '0','1' after 200 ns,'0' after 400 ns,'1' after 600 ns
,'0' after 800 ns,'1' after 1000 ns,'1' after 1200 ns,'0' after 1400 ns,'1' after 1600 ns
,'0' after 1800 ns,'1' after 2000 ns;
end signal_mapping_tb_arc;
