Frnds,
Myself doing project on FPGA as part of academics. I need a Level shifter IC between 8-bit Parallel Flash ADC and FPGA. Purpose is to convert high level voltage 5V to 3.3V (acceptable by FPGA)& no shift required in low level. & also I plan to use 8-bit ADC, so if you have used or know any IC which helps in high level shifter accepting 8-bit input parallely, level shift & output parallely, with preferably less conversion time. could u please suggest it?
Regards,
sita
