catherine_smith
Junior Member level 1
Hi all.. I have a problem in solving structures in FEKO. I have a planar microstrip structure, with a dielectric and a ground plane. Can I know the method to give the feed from any point on the conductor to the ground, through the dielectric?
When I draw a wire from conductor to ground plane through the dielectric, and assign a 1V wire port to it, and then solve the problem, an error message appears:
"A segment has neither a node, nor a connection point". Please help.
